[GRASSLIST:3022] Re: problem when compiling grass-jni under linux.
Markus Neteler neteler at itc.it
Tue Jan 29 05:06:36 EST 2002
On Tue, Jan 29, 2002 at 01:05:40AM -0500, Anand Mohan wrote:
> hi
>                    I am trying to install grass-jni in linux system.I did't get any binary file for linux.I downloaded the source file and trying to compile that one under linux.i am getting the            following error.
> make: **** No rule to make target usr/local/grass5/src/libes/LIB.linux', needed by 'libgis.so'. stop
> I think some people suceed in installing the grass-jni under linux.can i get any tips to over come this problem.
Did you completely compile the sources? It seems that
/usr/local/grass5/src/libes/LIB.linux
does not exist which indicates that the sources are not yet compiled.
Markus Neteler
