[GRASSLIST:3024] Re: help with GRASS 5.0 installation on linux
Ben Logan
ben at wblogan.net
Tue Jan 29 07:36:25 EST 2002
(I'm CCing the list just in case I tell you something wrong...maybe
someone can straighten me out. :)
On Tue, Jan 29, 2002 at 01:36:07PM +0200, Frank Tanser wrote:
> I downloaded the grass5.0.0pre3_i686-pc-linux-gnu_bin.tar.gz and
> grass5_i686-pc-linux-gnu_install.sh files.
I think you should just be able to run (as root)
./grass5_i686-pc-linux-gnu_install.sh
from the directory where you saved the files.
If it works like the pre2 installer, it will print a usage message.
You will probably only need to type
./grass5_i686-pc-linux-gnu_install.sh grass5.0.0pre3_i686-pc-linux-gnu_bin.tar.gz
I think that should do it. Let me know if something goes wrong.
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
