[GRASSLIST:3045] Re: Can't use r.resample
Ben Logan ben at wblogan.net
Wed Jan 30 08:05:27 EST 2002
On Tue, Jan 29, 2002 at 10:41:46PM -0800, Eric G. Miller wrote:
> Anyway, what version of GRASS do you have?  I fixed a bug about 1.5 months
I have version 5.0.0pre2.
> ago that could lead to such a problem if the output name was a GRASS
> fully qualified name (<name>@<mapset>).  I presume this doesn't happen if
> you don't use a fully qualified output name?
Sure enough, it works without specifying the mapset.  I hadn't tried
that.
Thanks,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
Criticism comes easier than craftsmanship.
		-- Zeuxis
