[GRASSLIST:4017] Re: error.log for Grass 5 Installation Problem
Glynn Clements
glynn.clements at virgin.net
Thu Jul 4 02:58:54 EDT 2002
Philip S. Wood wrote:
> Thanks for the help I've received so far,
> after checking the error.log I see that
> the Grass 5.0 system does not build without errors.
> Here is a copy of error.log:
> GRASS GIS compilation log
> Start of compilation: Wed Jul 3 14:16:49 SAST 2002
> Errors:
> Compilation error in module: src/libes/edit (ignored)
> Compilation error in module: src/general/init (ignored)
> Compilation error in module: src/general/g.region (ignored)
> Compilation error in module: src/mapdev/v.reclass (ignored)
> Compilation error in module: src/raster/r.reclass (ignored)
> Compilation error in module: src/raster/r.support (ignored)
> Compilation error in module: src/raster/r.weight (ignored)
> End of compilation: Wed Jul 3 18:04:41 SAST 2002
> DONE generating GRASS GIS binary code
> I see that "src/general/init" does not get built.
> The first error seems to be
> "Internal compiler error in subst_stack_regs_pat, at ..."
> Anyway the gcc version is 2.96.
This is a known problem, previously reported for Mandrake 8.2. The
compiler fails on libedit, then all programs which use libedit
(including src/general/init/set_data) fail.
> I'm going to try another version of gcc to see if that helps
It's reported that using "-O3" helps, e.g.
CFLAGS='-O3' ./configure ...
Glynn Clements <glynn.clements at virgin.net>
