[GRASSLIST:4040] Postgres and g.select.db problem.
Ben Logan
ben at wblogan.net
Sat Jul 6 07:21:53 EDT 2002
Good morning,
I compiled Postgres support into GRASS yesterday, and I already had
the Postgres database installed and working (with me as a user). I
ran
$ createdb virginia
CREATE DATABASE
And from within grass:
$ g.select.pg -l
The following databases are in the Unix catalogue:
template1
grass
virginia
As you can see, there's no problem connecting to the server. I can
also connect to the 'virginia' database with psql and create/drop
tables, etc.
$ g.select.pg database=virginia
Error: select Postgres:fe_sendauth: no password supplied
psql doesn't require a password, so I don't understand what's going on
here. I also get this message with the 'grass' database, which I also
have access to without a password (from psql and the python Postgres
library). Any idears?
Thanks,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
