[GRASSLIST:4048] Re: Postgres and g.select.db problem.
Christoph Simon ciccio at kiosknet.com.br
Sat Jul 6 21:24:03 EDT 2002
On Sat, 6 Jul 2002 21:11:05 -0400
Ben Logan <ben at wblogan.net> wrote:
> As you say, psql must use Unix sockets.
I didn't want to have said that. Using Unix sockets can be more
secure, as they allow to disable TCP sockets and should be used if no
access from other machines is needed. But if you do need network
access, TCP sockets are required and can be used also with psql. Then,
specially if this machine is accessible from the Internet, pg_hba.conf
should be adjusted carefully.
Christoph Simon
^X^C
q
quit
:q
^C
end
x
exit
ZZ
^D
help
