[GRASSLIST:4071] Re: ArcInfo Ungenerate for GRASS?
Eric G. Miller
egm2 at jps.net
Fri Jul 12 16:55:07 EDT 2002
On Fri, Jul 12, 2002 at 07:19:50PM +0200, Otto Dassau wrote:
> Dear GRASSlist,
> I would like to import ArcInfo vector coverages into GRASS/PostgreSQL
> using v.in.arc.pg. Does anybody has experiences exporting
> data properly for GRASS. The ungenerate command only exports topology
> without
> attribute table.
> I finally used v.in.shape.pg successfully, but I read it is still
> the old "unreliable" v.in.shape used in this modul.
> I am courious how the procedure for the ungenerate format from ArcInfo
> to GRASS would be.
> Maybe someone can give some hints even if it is not a real GRASS
> problem.
Use Arc/Info export format for coverages.
Eric G. Miller <egm2 at jps.net>
