[GRASSLIST:4094] RE: (no subject) compile grass5.0pre5
JGillette at rfmd.com JGillette at rfmd.com
Thu Jul 18 10:33:32 EDT 2002
This problem has been reported twice before.
See GRASSLIST:4017 and GRASSLIST:3692.
The solution reportedly is:
   CFLAGS='-O3' ./configure ...
when compiling. See GRASSLIST:4017 and GRASSLIST:3700.
http://op.gfz-potsdam.de/GRASS-List/Archive/maillist.html
John
> -----Original Message-----
> From: andresjavier.garcia [mailto:andresjavier.garcia at wanadoo.es]
> Hi;
> I've tried to compile grass5.0pre5, and found the following:
> First of all; ./configure doesn't find the libraries of
> LAPACK and BLAS; I am unable to find out the reason, because
> Ie got "libblas.so" and "liblapack.so", both in /usr/lib/.
> But, disregarding that; the main subject, is that (without
> choosing the aforementioned packages) the compilation process
> creates the log file:
> GRASS GIS compilation log
> Start of compilation: mié jul 17 20:50:32 CEST 2002
> ERRORS:
> Compilation error in module; src/libes/edit (ignored)
> Compilation error in module; src/general/init (ignored)
> Compilation error in module; src/libes/g.region (ignored)
> Compilation error in module; src/mapdev/v.reclass (ignored)
> Compilation error in module; src/raster/r.reclass (ignored)
> Compilation error in module; src/raster/r.support (ignored)
> Compilation error in module; src/raster/r.weight (ignored)
> End of compilation: mié jul 17 21:08:19 CEST 2002
> DONE generating GRASS GIS binary code
