[GRASSLIST:4100] Spherical earth
Charles Krouse Charles.Krouse at noaa.gov
Thu Jul 18 15:22:35 EDT 2002
I want to import and use NOAA CoastWatch sst raster data.  It is
projected in mercator with a spherical earth with a radius of
6371200.0m.  I thought that I had it defined but it appears a sphere can
not be used.  After the mercator projection and shpere definition, I get the following
projection: 99 (Mercator)
zone:       0
datum:      ** unknown (default: WGS84) **
ellipsoid:  ** unknown (default: WGS84) **
When displaying the data with this projection, it is obviously not accurate for the CoastWatch projection, and it appears to have used WGS84 as the default
ellipsoid.
Can anyone sugguest a work around?  Possibly define a = b in the
ellipse.table?   This method worked in other software that we used.
Thanks.
                                                Charlie
