[GRASSLIST:4152] Re: v.in.shape.pg won't import all the shapes.
Markus Neteler
neteler at itc.it
Thu Jul 25 11:54:13 EDT 2002
On Sat, Jul 06, 2002 at 09:22:26PM -0400, Ben Logan wrote:
> I am trying to import some shapefiles with v.in.shape.pg, and the
v.in.shape.pg is very outdated and disabled from the standard
compilation now.
Please use
v.in.shape + pg.in.dbf
now (v.in.shape from pre4 or pre5).
Markus
> PostgreSQL part seems to be working fine. However, the resulting
> vector file only contains a few shapes from the shapefile. One
> shapefile was a county boundary with only one shape (which was
> imported), but all parts of the shape weren't there--the level of
> detail was very low.
> Another shapefile contained several dozen lines, but only 3 were
> imported. This resulted in a whole bunch of "Failed to attach an
> attribute ... to a line." messages since there were lots of attributes
> but only 3 lines imported.
> I tried setting 'snapdist' to 0, and fiddling with 'scale,' but to no
> avail. v.in.shape imports the shapefiles okay.
> Thanks,
> Ben
