[GRASSLIST:3832] Re: .gislock problem
Markus Neteler
neteler at itc.it
Wed Jun 5 05:43:37 EDT 2002
On Wed, Jun 05, 2002 at 10:30:59AM +0200, Wouter Buytaert wrote:
> Hello,
> upgraded to grass5pre4 on my linux mandrake 8.2 system, and starting up
> gives a strange error:
> /usr/local/grass5/etc/Init.sh: /usr/local/grass5/etc/lock: No such file
> or directory
Hi Wouter,
it seems that the program
is missing.
Try to recompile
gmake5 -i src/general/init/
and check if 'lock' is compiled.
Good luck,
Markus
> Can't properly access /home/wouter/.gislock5
> please notify system personel
> However as root (su) I can start up grass
> Changing back to normal user (su wouter) also works
> Someaone who nows how to solve?
> Thanks!
> Wouter
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
