[GRASSLIST:3846] Re: Grass5.0.0pre4 Installation Problems
Glynn Clements glynn.clements at virgin.net
Fri Jun 7 07:39:28 EDT 2002
Neil.Murphy at axa.ie wrote:
> I am trying to instal grass5.0.0pre4 on Mandrake8.2
> configure confirmed the following
> make ran but the compilation log produced the following
> GRASS GIS compilation log
> Start of compilation: Thu Jun  6 07:33:59 IST 2002
> Errors:
> Compilation error in module: src/libes/edit (ignored)
> Compilation error in module: src/general/init (ignored)
> Compilation error in module: src/general/g.region (ignored)
> Compilation error in module: src/mapdev/v.reclass (ignored)
> Compilation error in module: src/raster/r.reclass (ignored)
> Compilation error in module: src/raster/r.support (ignored)
> Compilation error in module: src/raster/r.weight (ignored)
This looks like it might be related to curses, but I would need to see
the actual error messages to be sure.
> Compilation error in module: src/imagery/i.fft (ignored)
> Compilation error in module: src/imagery/i.zc (ignored)
> Compilation error in module: src/raster/r.surf.fractal (ignored)
> Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
This is likely to be due to a problem with the FFTW library.
> make install produced the following
> make[1]: *** [real-install] Error 1
> make[1]: Leaving directory `/home/neil/project/grass5.0.0pre4'
> make: *** [install] Error 2
This is a known bug in the pre4 build process; create the "locale"
subdirectory of the dist.<arch> directory manually.
Glynn Clements <glynn.clements at virgin.net>
