[GRASSLIST:3848] s.surf.idw help
Kevin Slover
Kevin.Slover at noaa.gov
Fri Jun 7 11:09:35 EDT 2002
I am attempting to use r.surf.idw to create a finer resolution data set
for GLOBE data. Currently, I have imported the data at .001 deg X .001
deg res, and am trying to get to .0005 X .0005 deg res...it starts fine,
reading in the input raster, however, will not read the entire raster...
When it is reading in the raster, is it storing it to memory before
starting the interpolation?? The first time I tried it, the message
simply said KILLED. I tried a second time, reducing the area of
interpolation, and it completely froze up my computer. I am using pre4
( I think), I downloaded from CVS 2 wks ago, on a RH7.2. Any
thoughts?? I think I might be trying to do too much...just my first
guestimate...
thanks...
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL 33165
W (305) 299-4456
