[GRASSLIST:3861] d.zoom question
    Kevin Slover
    Kevin.Slover at noaa.gov
    Tue Jun 11 13:52:12 EDT 2002
Maybe a bug, maybe not, may have even been covered...but I noticed that
if you are openning multiple raster files, and happen to remove one of
these files, you are not able to use d.zoom...
ex:
I am working with many many rasters (15) trying to figure out which are
good, and which are not.  Using the d.rast -o command, I open about 5,
and realize I have a bad raster (user error).  I g.remove, and continue
on with the d.rast -o (NOT using d.erase).  I then want to zoom, since I
am missing an area, and typing d.zoom:
ERROR:  Raster file [therastername.rast at PERMANENT] not available.
Is there anyway to work around this??  Thanks...
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL  33165
W (305) 299-4456
