[GRASSLIST:3868] Re: distance between polygons
Glynn Clements
glynn.clements at virgin.net
Wed Jun 12 09:40:19 EDT 2002
Johannes B|hler wrote:
> does anyone know a function or a method how to find out the shortest distance
> between two (and more) polygons, using GRASS? i was
> thinking about something like computing the distance of each polygon
> node to the nodes of the other polygon. and than just select the shortest
> ones.
That won't necessarily produce the correct answer. The shortest
distance could be between a vertex of one polygon and a point on an
edge of the other polygon.
Glynn Clements <glynn.clements at virgin.net>
