[GRASSLIST:3873] Re: Jobs running in background - changing region for another job??
Stephan Holl
sholl at gmx.net
Wed Jun 12 15:32:32 EDT 2002
Hello List,
> > I am not quite sure about the topic I described in subject line.
> > I am going to run a huge watershed calculation in background, but
> > there is something I am a bit worried about.
> > What happens, when I change regions settings during background
> > calculation for some other things (e.g. zooming and panning, or
> > setting up mask...)?
> *Should* be possible if the raster module reads the map once only.
The r.watershed module does not care about changing regions during
calculation. Everything seemed to be all right.
thanks for your comments
steph
Linux: the operating system with a CLUE...
Command Line User Environment.
Stephan Holl
GnuPG Key-ID: 11946A09
ICQ# 117277975
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020612/c51716b3/attachment.bin
