[GRASSLIST:3891] Grass5.0.0pre4 Installation Problems(cont.)
Neil.Murphy at axa.ie Neil.Murphy at axa.ie
Mon Jun 17 04:19:26 EDT 2002
Hi All,
I am still trying to install Grass5.0.0pre4 correctly on Mandrake 8.2
When I try to run grass I get the following as a user or as root
[neil at localhost bin.i686-pc-linux-gnu]$ ./grass5
/home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/Init.sh:
/home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/lock: No such
file or directory
Unable to properly access /home/neil/.gislock5
Please notify system personel.
I notice a previous mail on the list that suggested
"Try to recompile
gmake5 -i src/general/init/
and check if 'lock' is compiled." So I tried this and got the following
neil at localhost bin.i686-pc-linux-gnu]$ ./gmake5 -i
/home/neil/project/grass5.0.0pre4/src/general/init/
  SRC     = /home/neil/project/grass5.0.0pre4/src
  CMD     = /home/neil/project/grass5.0.0pre4/src/CMD
  UNUSED  = /home/neil/project/grass5.0.0pre4/unused
  HEADER  = head.i686-pc-linux-gnu
  ARCH    = i686-pc-linux-gnu
  GISBASE = /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu
  VERSION = 5.0.0pre4 May 2002
  make -f OBJ.i686-pc-linux-gnu/make.rules
rm -f /home/neil/project/grass5.0.0pre4/bin.i686-pc-linux-gnu/grass`cat
/home/neil/project/grass5.0.0pre4/src/CMD/VERSION
 | head -1 | sed 's/\..*//'` ; true
/bin/sh -c "sed -e
\"s#GISBASE_VALUE#/home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu#\"
-e \"s#PERL_COMMAND#/
usr/bin/perl#\" grass.src >
| head -1 | sed 's/\..*//'` 2>/dev/null ; true"
chmod a+x /home/neil/project/grass5.0.0pre4/bin.i686-pc-linux-gnu/grass`cat
make: *** No rule to make target
`/home/neil/project/grass5.0.0pre4/src/libes/LIB.i686-pc-linux-gnu/libedit.a',
needed by
dist.i686-pc-linux-gnu/etc/set_data'.  Stop.
Thanks for any help I can get
Arrange your Insurance online with www.AXA.ie
Car Quote : http://www.axa.ie/motorpol/requestquote.html
Home Quote : http://www.axa.ie/homepol/request.html
The contents and any attachments of this electronic mail message are
confidential and intended only for the named addressees.
Dissemination, forwarding, publication or other use of the message
or attachments by any unauthorised person is strictly prohibited.
Unless stated to the contrary, any opinions expressed in this message
are personal and may not be attributed to AXA Ireland, AXA Insurance,
or any member of the AXA Group of Companies.
Internet e-mails are not necessarily secure. AXA Group does not accept
responsibility for changes made to this message after it was sent.
