[GRASSLIST:3902] Re: Trouble compiling GRASS for cygwin
Markus Neteler
neteler at itc.it
Mon Jun 17 12:04:00 EDT 2002
On Mon, Jun 17, 2002 at 04:11:24PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > I try to compile GRASS5 for the cygwin-environment. The trouble is,
> > > > that I always get the following error-message while running the
> > > > configure script: "checking for xdrmem_create in -lrpclib... no \n
> > > > configure: error: *** Unable to locate XDR functions." and something
> > > > else. so teh file can't be found, but i have no idea, where i could
> > > > get it.
> > > http://grass.itc.it/grass5/binary/windows_cygnus/sunrpc/sunrpc-4.0.cygwin1.bin.tar.gz
> > You may also read the compile instructions:
> > http://grass.itc.it/grass5/binary/windows_cygnus/cygwin_grass50compile.html
> Maybe that file should be changed to include an absolute URL?
> Currently, it has:
> <br><a href="sunrpc/"><tt>sunrpc-4.0.cygwin1.bin.tar.gz</a></tt>
> This works if you are reading cygwin_grass50compile.html on the web
> site, but not if you're reading the local copy in the "documents"
> directory.
Yes, good idea. Done.
Markus
