[GRASSLIST:3900] Re: Trouble compiling GRASS for cygwin
Glynn Clements
glynn.clements at virgin.net
Mon Jun 17 11:11:24 EDT 2002
Markus Neteler wrote:
> > > I try to compile GRASS5 for the cygwin-environment. The trouble is,
> > > that I always get the following error-message while running the
> > > configure script: "checking for xdrmem_create in -lrpclib... no \n
> > > configure: error: *** Unable to locate XDR functions." and something
> > > else. so teh file can't be found, but i have no idea, where i could
> > > get it.
> > http://grass.itc.it/grass5/binary/windows_cygnus/sunrpc/sunrpc-4.0.cygwin1.bin.tar.gz
> You may also read the compile instructions:
> http://grass.itc.it/grass5/binary/windows_cygnus/cygwin_grass50compile.html
Maybe that file should be changed to include an absolute URL?
Currently, it has:
<br><a href="sunrpc/"><tt>sunrpc-4.0.cygwin1.bin.tar.gz</a></tt>
This works if you are reading cygwin_grass50compile.html on the web
site, but not if you're reading the local copy in the "documents"
directory.
Glynn Clements <glynn.clements at virgin.net>
