[GRASSLIST:3910] Re: list GRASSLIST: List Message Rejected
Glynn Clements glynn.clements at virgin.net
Tue Jun 18 22:57:40 EDT 2002
John Wharton wrote:
> I made a new LOCATION "103" in my D:\cygwin\home\grassdata where
> Spearfish is.
How did you create the location? From the GRASS startup screen? Don't
try to create it manually.
> And put a Rel 12 DXF in there.
Don't directly add, remove or modify files in the GRASS database
directory.
> But v.in.dxf can't open it. What am I doing wrong?
Programs which operate on files rather than GRASS maps (e.g. *.in.*
and *.out.* programs) will look for them in the current directory
unless a full pathname is specified.
> Do I need something else in the Location or Mapset structure??
You don't need to know anything about the contents of /home/grassdata.
Or, at least, you shouldn't need to know.
Glynn Clements <glynn.clements at virgin.net>
