[GRASSLIST:3911] about s.surf.krig.cerl
Xueming Wu xwu at cse.unl.edu
Wed Jun 19 14:37:11 EDT 2002
Greetings,
Has anyone used the kriging interpolation of Grass?
Does it work? I downloaded the source code of
"s.surf.krig.cerl". It can't run in Grass 5.0. So
I made some modifications to the source code. It
can run now. But result of interpolation doesn't
look like correct. But I made no change to the
algorithm of kriging. So I want to figure out if
the algorithm of the kriging is correct.
Thanks a lot.
Xueming
