I'm using grass5.0.0preX on linux. From the module list on the general infomation page (http://www3.baylor.edu/grass/grass5/index.html), m.in.stf1.db3 should still be available, but GRASS complaint: "Command not found" when I tried to call it. Has the module been removed or renamed? Thanks. -rengie
