[GRASSLIST:3915] install grass5.0.0pre4 from source under FreeBSD4.4
Jeff D. Hamann jeff_hamann at hamanndonald.com
Thu Jun 20 03:48:46 EDT 2002
I've been trying to install GRASS5.0.0pre4 (the /usr/ports has grass5beta8)
on FreeBSD and keep running into the following problem (the docs state that
the dbm isn't required, but is installed on my system)....
install -c -o root -g wheel -m 444 -o bin -g bin gdbm.h
/usr/local/include/gdbm.h
install -c -o root -g wheel -m 444 -o bin -g bin ./gdbm.3 \
/usr/local/man/man3/gdbm.3
install -c -o root -g wheel -m 444 -o bin -g bin ./gdbm.info \
/usr/local/info/gdbm.info
===> Generating temporary packing list
===> Compressing manual pages for gdbm-1.8.0
===> Running ldconfig
/sbin/ldconfig -m /usr/local/lib
===> Registering installation for gdbm-1.8.0
lummox#
from ./configure
checking for location of DBM includes...
checking for dbm.h... no
configure: error: *** Unable to locate DBM includes.
lummox#
so I started using the --without switches and so far none of the packages
are working in the ./configure file.
lummox#
./configure --without-dbm --without-jpeg --without-tiff --without-png --with
out-gd
and on and on and on....
checking whether to use PNG... no
checking whether to use GD... no
checking whether to use Tcl/Tk... yes
checking for location of Tcl/Tk includes...
checking for tcl.h... no
configure: error: *** Unable to locate Tcl includes.
lummox#
I have most of of the default=yes packages and they all seem to fail...
Is there a path/environment variable I need to set?
Thanks,
Jeff.
Jeff D. Hamann
Hamann, Donald & Associates, Inc.
PO Box 1421
Corvallis, Oregon USA 97339-1421
Bus. 541-753-7333
Cell. 541-740-5988
www.hamanndonald.com
