[GRASSLIST:3916] Re: Grass5.0.0pre4 Installation Problems(cont.)
Neil.Murphy at axa.ie
Thu Jun 20 04:21:18 EDT 2002
Thanks Glynn
Here is the result from gmake5 src/libes/edit".
[neil at localhost bin.i686-pc-linux-gnu]$ gmake5
/home/neil/project/grass5.0.0pre4
/src/libes/edit/
SRC = /home/neil/project/grass5.0.0pre4/src
CMD = /home/neil/project/grass5.0.0pre4/src/CMD
UNUSED = /home/neil/project/grass5.0.0pre4/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu
VERSION =5.0.0pre4May2002
/home/neil/project/grass5.0.0pre4/src/libes/edit
make -f OBJ.i686-pc-linux-gnu/make.rules
gcc -I/home/neil/project/grass5.0.0pre4/src/include -g -O2 -c
edit_cellhd.c
-o OBJ.i686-pc-linux-gnu/edit_cellhd.oedit_cellhd.c:
In function `format_value':
edit_cellhd.c:112: Internal compiler error in subst_stack_regs_pat, at
reg-stack.c:
1414Please submit a full bug report.
See <URL:https://qa.mandrakesoft.com/> for instructions.
make: *** [OBJ.i686-pc-linux-gnu/edit_cellhd.o] Error 1
Neil.Murphy at axa.ie wrote:
> I am still trying to install Grass5.0.0pre4 correctly on Mandrake 8.2
> When I try to run grass I get the following as a user or as root
> [neil at localhost bin.i686-pc-linux-gnu]$ ./grass5
> /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/Init.sh:
> /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/lock: No
such
> file or directory
> Unable to properly access /home/neil/.gislock5
> Please notify system personel.
> I notice a previous mail on the list that suggested
> "Try to recompile
> gmake5 -i src/general/init/
> and check if 'lock' is compiled." So I tried this and got the following
[snip]
> make: *** No rule to make target
`/home/neil/project/grass5.0.0pre4/src/libes/LIB.i686-pc-linux-gnu/libedit.a',
Send me the errors which result from "gmake5 src/libes/edit".
Glynn Clements <glynn.clements at virgin.net>
Arrange your Insurance online with www.AXA.ie
Car Quote : http://www.axa.ie/motorpol/requestquote.html
Home Quote : http://www.axa.ie/homepol/request.html
The contents and any attachments of this electronic mail message are
confidential and intended only for the named addressees.
Dissemination, forwarding, publication or other use of the message
or attachments by any unauthorised person is strictly prohibited.
Unless stated to the contrary, any opinions expressed in this message
are personal and may not be attributed to AXA Ireland, AXA Insurance,
or any member of the AXA Group of Companies.
Internet e-mails are not necessarily secure. AXA Group does not accept
responsibility for changes made to this message after it was sent.
