[GRASSLIST:3922] RE: install grass5.0.0pre4 from source under Fre
eBSD4.4
Andrew MacIntyre
Andrew.MacIntyre at aba.gov.au
Thu Jun 20 20:13:30 EDT 2002
I would expect that /usr/local/include is not being searched for include
files. You should see a "-I/usr/local/include" in each compiler
invocation.
I would suggest that you look at the patches for the port version, to see
whether they modify the configure files at all, and try any such
modifications to see whether they help. IIRC, there's also a configure
option to explicitly add include file paths, but I can't recall what it
is off the top of my head.
If you can get it built, it would be great if you were in a position to
submit patches to update the port.
Andrew MacIntyre \ E-mail: andrew.macintyre at aba.gov.au
Planning & Licensing Branch \ Tel: +61 2 6256 2812
Australian Broadcasting Authority \ Fax: +61 2 6253 3277
-> "These thoughts are mine alone!" <----------------------------------
> -----Original Message-----
> From: Jeff D. Hamann [mailto:jeff_hamann at hamanndonald.com]
> Sent: Thursday, 20 June 2002 5:49 PM
> To: grasslist at baylor.edu
> Subject: [GRASSLIST:3915] install grass5.0.0pre4 from source under
> FreeBSD4.4
> I've been trying to install GRASS5.0.0pre4 (the /usr/ports
> has grass5beta8)
> on FreeBSD and keep running into the following problem (the
> docs state that
> the dbm isn't required, but is installed on my system)....
> install -c -o root -g wheel -m 444 -o bin -g bin gdbm.h
> /usr/local/include/gdbm.h
> install -c -o root -g wheel -m 444 -o bin -g bin ./gdbm.3 \
> /usr/local/man/man3/gdbm.3
> install -c -o root -g wheel -m 444 -o bin -g bin ./gdbm.info \
> /usr/local/info/gdbm.info
> ===> Generating temporary packing list
> ===> Compressing manual pages for gdbm-1.8.0
> ===> Running ldconfig
> /sbin/ldconfig -m /usr/local/lib
> ===> Registering installation for gdbm-1.8.0
> lummox#
> from ./configure
> checking for location of DBM includes...
> checking for dbm.h... no
> configure: error: *** Unable to locate DBM includes.
> lummox#
> so I started using the --without switches and so far none of
> the packages
> are working in the ./configure file.
> lummox#
> ./configure --without-dbm --without-jpeg --without-tiff
> --without-png --with
> out-gd
> and on and on and on....
> checking whether to use PNG... no
> checking whether to use GD... no
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes...
> checking for tcl.h... no
> configure: error: *** Unable to locate Tcl includes.
> lummox#
> I have most of of the default=yes packages and they all seem
> to fail...
> Is there a path/environment variable I need to set?
> Thanks,
> Jeff.
> Jeff D. Hamann
> Hamann, Donald & Associates, Inc.
> PO Box 1421
> Corvallis, Oregon USA 97339-1421
> Bus. 541-753-7333
> Cell. 541-740-5988
> www.hamanndonald.com
