[GRASSLIST:3947] Re: error while loading shared libraries
Markus Neteler neteler at itc.it
Tue Jun 25 13:24:18 EDT 2002
On Tue, Jun 25, 2002 at 07:16:13PM +0200, Ulrich Leopold wrote:
> the libraries are installed. Is this a path problem? Can I set a path
> for the libraries?
what does
ldd /usr/local/grass5/driver/PNG
tell you (assuming that GRASS is installed in /usr/local/grass5).
Check also
echo $LD_LIBRARY_PATH
if this includes the path to libgd.
Markus
> Ulrich
> Markus Neteler wrote:
> > Hi Ulrich,
> > On Tue, Jun 25, 2002 at 04:59:19PM +0200, Ulrich Leopold wrote:
> >>Dear list,
> >>Is the following error message a bug in GRASS5.0.0pre3 or a problem in
> >>my system?
> >>/usr/local/arch/grass5/driver/PNG: error while loading shared libraries:
> >>libgd.so: cannot open shared object file: No such file or directory
> > this library must be installed on your system. Please have a look at the
> > manual page:
> > g.manual pngdriver
> > where to acquire it.
> > Regards,
> >  Markus Neteler
> __________________________________________________
> Ulrich Leopold MSc.
> Department of Physical Geography
> Institute for Biodiversity and Ecosystem Dynamics
> Faculty of Science
> University of Amsterdam
> Nieuwe Achtergracht 166
> NL-1018WV Amsterdam
> Phone: +31-(0)20-525-7456 (7451 Secretary)
> Fax:   +31-(0)20-525-7431
> Email: uleopold at science.uva.nl
> http://www.frw.uva.nl/soil/Welcome.html
> Check us also out at:
> Netherlands Centre for Geo-ecological Research
> http://www.frw.uva.nl/icg
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
