[GRASSLIST:3948] Re: error while loading shared libraries
Ulrich Leopold uleopold at science.uva.nl
Tue Jun 25 13:34:02 EDT 2002
this is the result:
Mapset <nl500> in Location <Netherlands>
         GRASS 5.0.0pre3 > ldd /usr/local/grass5/driver/PNG
         libz.so.1 => /usr/lib/libz.so.1 (0x4002c000)
         libgd.so => not found
         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x4003a000)
         libpng.so.2 => /usr/lib/libpng.so.2 (0x40059000)
         libm.so.6 => /lib/libm.so.6 (0x4007b000)
         libc.so.6 => /lib/libc.so.6 (0x4009d000)
         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
         GRASS 5.0.0pre3 > echo $LD_LIBRARY_PATH
/usr/local/matlab_r12/extern/lib/glnx86:/usr/local/matlab_r12/sys/os/glnx86:/usr/local/arch/mozilla-0.9.6:/usr/local/arch/mozilla-1.0.0:/usr/local/arch/grass5/lib
libgd cannot be found and is not included in the path. How can I set the
path to libgd? It is in /usr/lib/.
Regards, Ulrich
Markus Neteler wrote:
> On Tue, Jun 25, 2002 at 07:16:13PM +0200, Ulrich Leopold wrote:
>>the libraries are installed. Is this a path problem? Can I set a path
>>for the libraries?
> what does
> tell you (assuming that GRASS is installed in /usr/local/grass5).
> Check also
> if this includes the path to libgd.
> Markus
>>Ulrich
>>>Hi Ulrich,
>>>On Tue, Jun 25, 2002 at 04:59:19PM +0200, Ulrich Leopold wrote:
>>>>Dear list,
>>>>Is the following error message a bug in GRASS5.0.0pre3 or a problem in
>>>>my system?
>>>>/usr/local/arch/grass5/driver/PNG: error while loading shared libraries:
>>>>libgd.so: cannot open shared object file: No such file or directory
>>>this library must be installed on your system. Please have a look at the
>>>manual page:
>>>g.manual pngdriver
>>>where to acquire it.
>>>Regards,
>>> Markus Neteler
>>__________________________________________________
>>Ulrich Leopold MSc.
>>Department of Physical Geography
>>Institute for Biodiversity and Ecosystem Dynamics
>>Faculty of Science
>>University of Amsterdam
>>Nieuwe Achtergracht 166
>>NL-1018WV Amsterdam
>>Phone: +31-(0)20-525-7456 (7451 Secretary)
>>Fax:   +31-(0)20-525-7431
>>Email: uleopold at science.uva.nl
>>http://www.frw.uva.nl/soil/Welcome.html
>>Check us also out at:
>>Netherlands Centre for Geo-ecological Research
>>http://www.frw.uva.nl/icg
Ulrich Leopold MSc.
Faculty of Science
NL-1018WV Amsterdam
