[GRASSLIST:3964] Re: m.in.ntf
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Jun 27 06:13:28 EDT 2002
On Thu, 27 Jun 2002, Roy Sanderson wrote:
> The source code I tried to install was from the Leicester 'Assist' site
> with additional GRASS code.  The install failed on gmake5 with the message
> that 51grid_rec.c has a macro failure on lines 185 and 214 due to only 2
> arguments being provided to strncpy.
I didn't even get that far. The version on the Leicester website is very
out of date.
> I'm not familiar with CVS, but tried downloading the gzipped tarball from
> the 'Attic' directory for m.in.ntf, but when I issue 'tar -xvf Attic.tar'
> it replies 'tar: Record size = 2 blocks' and no extraction occurs.  The
> filesize also looks suspiciously small at only 1024 Kb.
I got that as well; looks like a bug in the download tarball feature; I
think it has only recently been added to the CVS server anyway. When I did
it I just download all the files one-by-one (right-click save as). But I
will send you the source I downloaded this way separately (only about 60k)
> Perhaps I need to try and install ogr2ogr from somewhere, as suggested by
> Frank Warmerdam, but maybe even easier is to give up on NTF and try a dxf
> route.
Well if you have the option of using DXF I would say go with it as it is a
more universal well-defined format. Just my opinion though. With OSNI DXF
data though, it requires some manipulation of the vector attribute and
categories files after importing into GRASS. I hope to write a Perl script
to do this but haven't got round to it yet.
Also, I don't know why the comment in CVS says m.in.ntf is not functional
at all as it clearly does work; I'm just not sure how reliable it is.
Paul
> At 13:59 26/06/02 +0100, Paul Kelly wrote:
> >It is deleted from CVS so you have to download the attic version. It was
> >easy enough to do this from the CVS web interface. It compiled OK for me;
> >what was your error? It seemed to work all right though I found a better
> >way of doing what I wanted so didn't investigate too much. Also I was
> >only using it with Ordnance Survey of Northern Ireland data---it might
> >work better with OS Great Britain NTF format
> >Paul K
> >> Hi
> >> I'm using GRASS5.0.0pre4 on RHL6.0, and notice m.in.ntf in the manual
> >> pages, which sounds ideal for the task of important UK Ordnance Survey
> >> digital data.  But when I issue the command it says 'command not found',
> >> and having located the source on the web, it won't compile.  Any clues?
> >> Thanks
> >> Roy
