[GRASSLIST:3963] Re: m.in.ntf
Roy Sanderson
R.A.Sanderson at newcastle.ac.uk
Thu Jun 27 06:34:35 EDT 2002
The source code I tried to install was from the Leicester 'Assist' site
with additional GRASS code. The install failed on gmake5 with the message
that 51grid_rec.c has a macro failure on lines 185 and 214 due to only 2
arguments being provided to strncpy.
I'm not familiar with CVS, but tried downloading the gzipped tarball from
the 'Attic' directory for m.in.ntf, but when I issue 'tar -xvf Attic.tar'
it replies 'tar: Record size = 2 blocks' and no extraction occurs. The
filesize also looks suspiciously small at only 1024 Kb.
Perhaps I need to try and install ogr2ogr from somewhere, as suggested by
Frank Warmerdam, but maybe even easier is to give up on NTF and try a dxf
route.
Roy
At 13:59 26/06/02 +0100, Paul Kelly wrote:
>It is deleted from CVS so you have to download the attic version. It was
>easy enough to do this from the CVS web interface. It compiled OK for me;
>what was your error? It seemed to work all right though I found a better
>way of doing what I wanted so didn't investigate too much. Also I was
>only using it with Ordnance Survey of Northern Ireland data---it might
>work better with OS Great Britain NTF format
>Paul K
>> Hi
>> I'm using GRASS5.0.0pre4 on RHL6.0, and notice m.in.ntf in the manual
>> pages, which sounds ideal for the task of important UK Ordnance Survey
>> digital data. But when I issue the command it says 'command not found',
>> and having located the source on the web, it won't compile. Any clues?
>> Thanks
>> Roy
>> Roy Sanderson
>> Centre for Life Sciences Modelling
>> Porter Building
>> University of Newcastle
>> Newcastle upon Tyne
>> NE1 7RU
>> United Kingdom
>> Tel: +44 191 222 7789
>> Fax: +44 191 222 6563
>> r.a.sanderson at newcastle.ac.uk
>> http://www.ncl.ac.uk/clsm
