[GRASSLIST:3959] Re: m.in.ntf
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Jun 26 08:59:42 EDT 2002
It is deleted from CVS so you have to download the attic version. It was
easy enough to do this from the CVS web interface. It compiled OK for me;
what was your error? It seemed to work all right though I found a better
way of doing what I wanted so didn't investigate too much. Also I was
only using it with Ordnance Survey of Northern Ireland data---it might
work better with OS Great Britain NTF format
Paul K
> Hi
> I'm using GRASS5.0.0pre4 on RHL6.0, and notice m.in.ntf in the manual
> pages, which sounds ideal for the task of important UK Ordnance Survey
> digital data.  But when I issue the command it says 'command not found',
> and having located the source on the web, it won't compile.  Any clues?
> Thanks
> Roy
> Roy Sanderson
> Centre for Life Sciences Modelling
> Porter Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 222 7789
> Fax: +44 191 222 6563
> r.a.sanderson at newcastle.ac.uk
> http://www.ncl.ac.uk/clsm
