[GRASSLIST:3955] Re: m.in.ntf
Tue Jun 25 15:21:34 EDT 2002
Bernhard Reiter wrote:
> Reading the CVS logs I can see that m.in.ntf was removed from the
> release in February. The log message says that it is not functional
> and its task will be taken over by gdal.
> So you probably found a documentation bug. :)
> Thus try gdal to convert the data before importing them with grass.
Folks,
Note that r.in.gdal will only read raster NTF files ... that is the
various gridded DEM products.  To read NTF vector products use the
ogr2ogr utility within the GDAL/OGR distribution to turn the files into
shapefiles then import that with v.in.shape.
Best regards,
