[GRASSLIST:3954] Re: m.in.ntf
    Bernhard Reiter
    bernhard at intevation.de
    Tue Jun 25 14:47:53 EDT 2002
Reading the CVS logs I can see that m.in.ntf was removed from the
release in February. The log message says that it is not functional
and its task will be taken over by gdal.
So you probably found a documentation bug. :)
Thus try gdal to convert the data before importing them with grass.
On Tue, Jun 25, 2002 at 05:03:21PM +0000, Roy Sanderson wrote:
> I'm using GRASS5.0.0pre4 on RHL6.0, and notice m.in.ntf in the manual
> pages, which sounds ideal for the task of important UK Ordnance Survey
> digital data.  But when I issue the command it says 'command not found',
> and having located the source on the web, it won't compile.  Any clues?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020625/6b0127c8/attachment.bin
