[GRASSLIST:3968] Re: error using batch-grass.sh
Markus Neteler neteler at itc.it
Thu Jun 27 09:31:07 EDT 2002
On Thu, Jun 27, 2002 at 02:57:46PM +0200, Andrew Wade wrote:
> Hi
> I am trying to use grass script base by running batch-grass.sh.
> When running the script though, I get the following error (I am just
> trying to run r.what for now until I have sorted out the minor
> problems).
> ERROR: program 'r.what' cannot be executed because : Neither a
> command line (cmd) or interactive (inter) version was found.
> What does this mean?  Grass is running when I start batch-grass
> and I am using the -file option to keep it all script based.  What do I
> need to do?
> btw I'm using 5pre4 on MandrakeLinux 8.2
Please have another look at the script:
http://grass.itc.it/faq/batch-grass.sh
I have slightly modified it. You will have to customize the path,
the information inside the file.
Markus
