[GRASSLIST:3982] Re: GLIBC_2.2 not found
Steve Kimball
kimball at signatron.com
Fri Jun 28 17:39:38 EDT 2002
Kirk,
I'm also runnig Red Hat 6.2 and got
r.in.ascii: /lib/libc.so.6: version 'GLIBC_2.2` not found (required
for r.in.ascii)
What did you do to fix it?
Steve Kimball
Glynn Clements wrote:
> Kirk Schmidt wrote:
> > I am running Grass 5.0.pre3 on RH 6.2
> > I tried to install gdal but ran into a core dump when the routine
> > could not locate GLIBC_2.2
> That suggets that you are using a binary version of GDAL which isn't
> compatible with your system. You need to either find a binary
> distribution which was build specifically for RedHat 6.2, or compile
> GDAL from source code.
> Glynn Clements <glynn.clements at virgin.net>
