[GRASSLIST:3834] Re: GDAL Installation Snag
Glynn Clements glynn.clements at virgin.net
Thu Jun 6 00:52:26 EDT 2002
Kirk Schmidt wrote:
> I am running Grass 5.0.pre3 on RH 6.2
> I tried to install gdal  but  ran into a core dump when the routine
> could not locate GLIBC_2.2
That suggets that you are using a binary version of GDAL which isn't
compatible with your system. You need to either find a binary
distribution which was build specifically for RedHat 6.2, or compile
GDAL from source code.
Glynn Clements <glynn.clements at virgin.net>
