[GRASSLIST:3277] Re: pre3 and r.in.gdal
Glynn Clements glynn.clements at virgin.net
Sun Mar 3 10:21:35 EST 2002
John Dougherty wrote:
> I have run into a problematic circumstance with pre3 and r.in.gdal.
> I compiled pre3 from source without errors.  Pre2 ran fine, and did not give
> trouble with r.in.gal, that I noticed any way.  I did have to get advise
> (thanks to you did) to add a couple of pointers for directories during the
> configure step for pre3, but otherwise had no problems.  Upon running
> r.in.gdal however, I get the following error:
> LD_LIBRARY_PATH = /usr/local/grass5/lib
> ERROR: Unable to initialize GDAL bridge (check libgdal
>        installation/LD_LIBRARY_PATH variable).
> The pre3 configure.in file checks for gdal availability and does not seem to
> notice its absence, but r.in.gdal looks for shared libraries that it is not
> finding.
The configure script doesn't check for either the GDAL library or its
headers unless you specify --with-gdal. The default is to build a
version of r.in.gdal which loads libgdal dynamically via dlopen().
The above error message indicates that you are using a version of
r.in.gdal which uses dlopen() rather than having been linked against
libgdal. The binary will look for libgdal in the directories
$GISBASE/lib and $GDAL_HOME, then using the loader's default search
path.
For each location, it will try each of the filenames:
	libgdal.1.1.so
	gdal.1.0.so
	gdal.so.1.0
	libgdal.so.1
Glynn Clements <glynn.clements at virgin.net>
