[GRASSLIST:3276] pre3 and r.in.gdal
John Dougherty
jwd at softcom.net
Sun Mar 3 04:03:55 EST 2002
I have run into a problematic circumstance with pre3 and r.in.gdal.
I compiled pre3 from source without errors. Pre2 ran fine, and did not give
trouble with r.in.gal, that I noticed any way. I did have to get advise
(thanks to you did) to add a couple of pointers for directories during the
configure step for pre3, but otherwise had no problems. Upon running
r.in.gdal however, I get the following error:
LD_LIBRARY_PATH = /usr/local/grass5/lib
ERROR: Unable to initialize GDAL bridge (check libgdal
installation/LD_LIBRARY_PATH variable).
The pre3 configure.in file checks for gdal availability and does not seem to
notice its absence, but r.in.gdal looks for shared libraries that it is not
finding.
Is there any other way to bring stdts dem data, for grass, that I can use
while unraveling why gdal won't compile properly for this system, this time?
JWDougherty
