[GRASSLIST:3275] Re: Topmodel parameter file
Markus Neteler
neteler at itc.it
Sat Mar 2 08:51:26 EST 2002
Helena,
(cc grasslist)
coming back to the Topmodel parameter file:
On Sat, Mar 02, 2002 at 08:55:59PM +0900, GRASS wrote:
> Markus wrote:
> > Once you worked with Topmodel. Would it be possible to
> > send an example parameter file? There were some questions
> > on that recently in the mailing list.
> Well, an example is already in CVS tree: src/raster/r.topmodel/example.
> Two files are available: input and param.
> Would you check these files?
> Best Regards,
> Huidae Cho
... it seems we all didn't look into the source code :-)
Markus
