[GRASSLIST:3327] Re: d.mon error in GRASS GIS 5.0.0pre3
Glynn Clements
glynn.clements at virgin.net
Mon Mar 11 23:24:07 EST 2002
Francois Delclaux wrote:
> I downloaded the GRASS 5.0.0pre3 sources in my
> RedHat7.1 system. Configuring and compiling were OK.
> Executing Grass5 is OK, too, but when the monitor starts with
> d.mon command, it fails with the following comment :
> GRASS 5.0.0pre3 > d.mon x0
> using default visual which is TrueColor
> ncolors: 65536
> Graphics driver [x0] started
> ERROR: G_realloc: out of memory
> Problem selecting x0. Will try once more
Can you please try the following:
d.mon -s start=x0 &> /dev/null
d.mon select=x0
That will indicate whether mon.select or XDRIVER is generating the
error; if you still get the error message, it's mon.select, otherwise
it's XDRIVER.
Also, do you have "gdb"?
Glynn Clements <glynn.clements at virgin.net>
