[GRASSLIST:3343] r.in.gdal segmentation error in Mandrake 8.1
John Dougherty
jwd at softcom.net
Mon Mar 18 20:31:55 EST 2002
I have repeatedly now, recompiled both GRASS 5.0.0pre3 and the GDAL (1.1.6)
library from remotesensing.org. Both of these code sets compile without
error messages or complaints about missing libraries or wrong verions.
"gdalinfo" properly identifies and displays data on SDTS dem files. However,
r.in.gdal persistantly terminates with a "segmentation fault" message, once
the input and put data have been entered and the program runs.
I have ran a "make clean" before recompiling with visible difference in the
results. The compilation has been conducted on clean, updated code base from
the respective CVS servers. GCC -v gives the following:
Reading specs from /usr/lib/gcc-lib/i586-mandrake-linux-gnu/2.96/specs
gcc version 2.96 20000731 (Mandrake Linux 8.1 2.96-0.62mdk)
I am also running into an anomalous result from r.in.bin if I try reading in
a dem generated by SDTS2DEM. The command simply ends without an error
message, but no new files show up in the location cell directory or anywhere
else I can find.
As far as I can see the *only* change between now and my last successful
compile was that I moved from SuSE 7.3 to MDK 8.1. Is anyone there running
MDK 8.1 and successfully using these programs? If you are, please let me
know your settings?
Thanks,
JWDougherty
