[GRASSLIST:3364] Re: A question about labeling.
Markus Neteler
neteler at itc.it
Sun Mar 24 14:01:32 EST 2002
On Sun, Mar 24, 2002 at 08:57:18AM -0700, Roger Miller wrote:
> On Sunday 24 March 2002 06:29, Ben Logan wrote:
> > Hello,
> > My question is regarding the positioning of labels. Once I have
> > labels attached to a vector map, do I have to position each one
> > manually?
> I wasn't aware of any way to attach labels to vectors so that they would need
> to be positioned. How are you doing that? The process of "labeling" a
> vector object in GRASS generally just means assigning the vector class an
> attribute text. You can read the label when you query an object, but it
> isn't otherwise displayed.
At least you can display cats/atts with
d.vect.labels
d.rast.labels
in a recent GRASS 5.0preX.
> You can place text on a map using the paint commands or with ps.map. In
> either case the labels are not attached to an object and they must be
> positioned manually. If you want to warp text around a curve then you would
> have to place each character separately.
Hopefully we find a neat solution for that in GRASS 5.1.
Markus Neteler
