[GRASSLIST:3369] Re: Calculating cumulative change in elevation.
Rod Paterson
rpaterso at bigpond.net.au
Sun Mar 24 23:48:08 EST 2002
Ben,
You could use v.to.rast to convert each vector line to a site list using
the Dmax option to set the distance between vector nodes to a distance a bit
less than the elevation raster cell size and then run s.sample using the new
site list and the elevation raster and option attr=none. This will give you a
new site list with the elevation values for each site (point along your vector).
>From there you could export to a spreadsheet and sum the positive and negative
elevation differences along your road/track or use R?
regards
Rod Paterson
-----Original Message-----
To: The GRASS list <grasslist at baylor.edu>
Date: Monday, 25 March 2002 14:26
Subject: [GRASSLIST:3367] Calculating cumulative change in elevation.
>I have a raster elevation map (imported DEM) and a vector map
>representing roads. I would like to use the elevation data to find
>the total (cumulative) distance you would ascend/descend in traversing
>a particular line. Note that I'm not talking about just the
>difference in elevation between the start and end points. Also, the
>vector map would only contain the one path to follow.
>Can anyone suggest a way to do this in GRASS?
>Thanks,
>Ben
>Ben Logan: ben at wblogan dot net
>OpenPGP Key KeyID: A1ADD1F0
