[GRASSLIST:3373] Re: Calculating cumulative change in elevation.
    Ben Logan
    ben at wblogan.net
    Mon Mar 25 06:12:02 EST 2002
On Sun, Mar 24, 2002 at 09:00:04PM -0700, Roger Miller wrote:
> Well, if you just accumulate the change in elevation along any route then
> your result will be equal to the difference between your beginning and ending
> elevations, so i suspect you mean something else.  Do you mean to produce two
> values, one for ascent and one for descent?
Right.  I mean produce two values as you say.
> You might be able to do something with r.cost.  You would need to construct a
> raster map that gives the change in elevation along the road.  It wouldn't be
> at all straight foreward.
That does sound complicated (perhaps just because I've never used
r.cost).  I think I'll try Mr. Paterson's suggestion, and if that
doesn't work, I'll pursue this one.
Thanks for your help,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
Seeing is believing.  You wouldn't have seen it if you hadn't believed it.
