[GRASSLIST:3389] Re: r.mapcalc reduces my raster map to 255 cats
Glynn Clements
glynn.clements at virgin.net
Tue Mar 26 08:34:06 EST 2002
Ben Logan wrote:
> I have some DEMs with 30 meter resolution, and the elevation values
> appear to be in feet instead of meters like the 10 meter res DEMs. It
> looked like I could convert the feet to meters with r.mapcalc, so I
> ran it with
> elev=elev30/3.28
> as the expression. It suceeded, but r.info says that my new map
> (elev) only has 255 categories. The original (elev30) had 2441. It
> seems to me that I should have the same number of categories...am I
> missing something?
In the above case, r.mapcalc will produce a floating-point map.
Floating-point maps don't really have categories. The values can be
coerced into categories using the map's quantisation rules, but only a
few programs (e.g. r.stats) do this. Most programs just use the exact
floating-point value.
The quantisation rules can be changed with r.quant.
Also, you can force r.mapcalc to generate an integer map using the
"int(...)" operator, i.e.
r.mapcalc 'elev=int(elev30/3.28)'
I would expect that to have ~745 categories (one for each metre of the
range, rather than one per foot).
Glynn Clements <glynn.clements at virgin.net>
