[GRASSLIST:3618] Re: dxf importing
Andrej Ivanovic
andriy at volja.net
Wed May 1 13:17:03 EDT 2002
>TIFF and DXF formats are handled through completely different import
>tools and result in completely different types of files; TIFF files
>import to raster files and DXF files import to vector files. You would
>not run v.support on an imported TIFF file.
I understand that and I tried to run v.support on imported DXF file, not on
imported TIFF file.
>Use v.in.dxf to import the DXF file. v.in.dxf is fairly robust, but it
>does not handle all types of dxf objects. Keep in mind that DXF files
>are often not in geographic coordinates. If that is true in your case
>then you may be able to use v.transform to supply the necessary
>coordinates. You should be able to view the imported file in a GRASS
>monitor without first running v.support, but that is about all you can
>do with the file.
The DXF I imported contained only lines and no other vector objects.
Neverthless, when importing was finished, I ran v.support and g.region on
it. After doing that it displayed correctly, but when I wanted to measure
distance of lines with v.report the result of all measurements was only one
category - NO DATA, and the distance was 0.
Thanks for your help,
Andrej Ivanovic
