[GRASSLIST:3697] Re: Compile Grass5.0.0pre4
Georges Schwob
schwob at respublica.fr
Tue May 21 08:52:58 EDT 2002
> On Tue, 21 May 2002 11:54:34 +0200, Markus wrote:
> Please try
> bin.i686-pc-linux-gnu/gmake5 src/libes/edit
> (you may adapt the path)
> and send us the error message.
> I assume that the "ncurses" package is not installed
(which you
> find on your Mandrake CDROM).
Hi Markus,
Here is the complete response given by the system at
the "gmake5 src/libes/edit" command:
-SRC=/home/grass_src/grass5.0.0pre4/src
-CMD=/home/grass_src/grass5.0.0pre4/src/CMD
-UNUSED=/home/grass_src/grass5.0.0pre4/UNUSED
-HEADER=head.i686-pc-linux-gnu
-ARCH=i686-pc-linux-gnu
-GISBASE=/home/grass_src/grass5.0.0pre4/dist.i686-pc-
linux-gnu
-VERSION=5.0.0pre4 May 2002
-/home/grass_src/grass5.0.0pre4/src/libes/edit
-make -f OBJ.i686-pc-linux-gnu/make.rules
-gcc -I/home/grass_src/grass5.0.0pre4/src/include -g -
02 -c edit_cellhd.c -o OBJ.i686-pc-linux-
gnu/edit_cellhd.o
-edit_cellhd.c:In fonction 'format_value':
-edit_cellhd.c:112:Internal compiler error in
subst_stack_regs_pat, at reg-stack.c:1414
-please submit a full bug report
-see <URL:https://qa.mandrakesoft.com/> for instructions
-make:*** [OBJ.i686-pc-linux-gnu/edit_cellhd.o] Erreur 1
That's all.
The libncurses5; libncurses5-devel; ncurses packages
are installed on the machine.
Thanks for your devotion.
Georges.
Découvrez sur Respublica et sur les sites du Groupe Tiscali France
une barre de navigation pour accéder en 1 clic aux meilleurs contenus
et services du Web.
http://www.tiscali.fr/minisite/
