[GRASSLIST:3698] Re: Compile Grass5.0.0pre4
Bernhard Reiter
bernhard at intevation.de
Tue May 21 09:42:05 EDT 2002
Please give us the output of "gcc -v".
Try to switch off optimisation, which
means leaving out the "-O2" when building GRASS.
I remember that Mandrake had a couple of problematic gcc
optimisations turned on by default in earlier versions.
Bernhard
On Tue, May 21, 2002 at 02:52:58PM +0200, Georges Schwob wrote:
> > On Tue, 21 May 2002 11:54:34 +0200, Markus wrote:
> > bin.i686-pc-linux-gnu/gmake5 src/libes/edit
> > and send us the error message.
> > I assume that the "ncurses" package is not installed
> Here is the complete response given by the system at
> the "gmake5 src/libes/edit" command:
> -SRC=/home/grass_src/grass5.0.0pre4/src
> -CMD=/home/grass_src/grass5.0.0pre4/src/CMD
> -UNUSED=/home/grass_src/grass5.0.0pre4/UNUSED
> -HEADER=head.i686-pc-linux-gnu
> -ARCH=i686-pc-linux-gnu
> -GISBASE=/home/grass_src/grass5.0.0pre4/dist.i686-pc-
> linux-gnu
> -VERSION=5.0.0pre4 May 2002
> -/home/grass_src/grass5.0.0pre4/src/libes/edit
> -make -f OBJ.i686-pc-linux-gnu/make.rules
> -gcc -I/home/grass_src/grass5.0.0pre4/src/include -g -
> 02 -c edit_cellhd.c -o OBJ.i686-pc-linux-
> gnu/edit_cellhd.o
> -edit_cellhd.c:In fonction 'format_value':
> -edit_cellhd.c:112:Internal compiler error in
> subst_stack_regs_pat, at reg-stack.c:1414
> -please submit a full bug report
> -see <URL:https://qa.mandrakesoft.com/> for instructions
> -make:*** [OBJ.i686-pc-linux-gnu/edit_cellhd.o] Erreur 1
> That's all.
> The libncurses5; libncurses5-devel; ncurses packages
> are installed on the machine.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020521/2e243b03/attachment.bin
