[GRASSLIST:3699] Re: Compile Grass5.0.0pre4
    Georges Schwob
    schwob at respublica.fr
    Tue May 21 10:11:05 EDT 2002
On Tue, 21 May 2002 15:42:05 +0200 Bernhard wrote:
> Subject : [GRASSLIST:3698] Re: Compile Grass5.0.0pre4
> Please give us the output of "gcc -v".
> Try to switch off optimisation, which
> means leaving out the "-O2" when building GRASS.
> I remember that Mandrake had a couple of problematic
gcc
> optimisations turned on by default in earlier
versions.
The output is:
-Reading specs from /usr/lib/gcc-lib/i586-mandrake-
linux-gnu/2.96/specs
-gcc version 2.96 20000731 (Mandrake Linux 8.2 2.96-
0.76mdk)
Regards
Georges Schwob
Découvrez sur Respublica et sur les sites du Groupe Tiscali France
une barre de navigation pour accéder en 1 clic aux meilleurs contenus
et services du Web.
http://www.tiscali.fr/minisite/
