[GRASSLIST:3733] RE: Grass 5.0.0pre4 RPMs for Mandrake 8.2
Buchan Milne
bgmilne at cae.co.za
Thu May 23 06:01:16 EDT 2002
Juan P. Rigol Sanchez wrote:
>>Currently there is just one RPM for grass, and it is built with
>>PostgreSQL, lapack, gdal support, and nvis. You should only need the
>>RPMs in the following directory.
> Buchan, could you send me the configure options you used for lapack,
> please? I cannot get lapack/blas compiled under 8.2 despite they
> are already installed.
I didn't compile lapack/blas, I used the precompiled packages. I had
problems compiling with lapack support, until I read the info on lapack,
(rpm -qi liblapack3) from which I gathered that I needed a fortran compiler!
I just had --with-lapack and --with-blas
I have also put up the SPEC files used for the RPMs, which will allow
you to see exactly how the RPMs were compiled.
http://ranger.dnsalias.com/mandrake/mandrake8.2/grass/gdal.spec
http://ranger.dnsalias.com/mandrake/mandrake8.2/grass/grass.spec
Btw, I am looking for some more experienced grass users to try my
packages, before I commit them to the Mandrake cooker contribs ... I
would appreciate some fedback, and then in the next release of Mandrake
you will be able to install it with 'urpmi grass'.
Regards,
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
