[GRASSLIST:3731] problem import shape file
Marco Kienzle m.kienzle at marlab.ac.uk
Thu May 23 14:55:16 EDT 2002
I am having many problems trying to import a .shp file (from ESRI) using
v.in.shape command although if the input file is a simple grid. The
problem is that in the resulting file many polygons have a area equal to
zero ??
I import the file with the following commands:
v.in.shape -o input=/home/kienzle/GIS/GRASS/poubelle/icesshape.shp
attribute=JOIN label=ICESSQ
Receive many of the following warnings:
WARNING: area 375 label: 1059 matched another label: 1059.
WARNING: area 406 label: 1060 matched another label: 1060.
WARNING: area 437 label: 1061 matched another label: 1061.
WARNING: area 468 label: 1062 matched another label: 1062.
WARNING: area 499 label: 1063 matched another label: 1063.
WARNING: area 530 label: 1064 matched another label: 1064.
And then check for the result with
v.report map=icesshape type=area units=k
Am I doing something wrong ? Is there something wrong in the original
file (although it works under ARC-INFO)?
thanks in advance,
marco
GIS: GRASS 5.0.0pre3 (January 2002)
OS: Linux 2.4.7-10 i686 RedHat 7.2
____________________________________________________________________________
Marco Kienzle
Fisheries Research Services
Marine Laboratory
PO Box 101 Victoria Road
Aberdeen AB119DB
United Kingdom
tel: +44 (0) 1224 876544
direct: +44 (0) 1224 295421
fax: +44 (0) 1224 295511
http://www.marlab.ac.uk
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020523/90e5c7a0/icesshape.obj
Type: application/x-xbase
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020523/90e5c7a0/icesshape.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020523/90e5c7a0/icesshape-0001.obj
